Hi All,
Need help on setting up a irule. Here is the requirement.
The web servers host mulitple application instance. We already have a test page being monitored. They added a new app instance and they want to monitor specific page and if all pool members fails, it should redirect to fall back pool only for the newly added instance.
Now, I created separate pool and assign monitor to check the new app page. However, I need help on setting up irule to check uri for /app and then point to a pool and if that pool fails it should direct to fall back pool.
Help Please.
Regards,
Sri
I currently have this…
if { [HTTP::uri] starts_with “/app1” } {
if { [active_members [LB::server pool]] == 0 } {
pool fall_back_pool
elseif { pool orginal_pool }
This doesnt help because the pool assigned with VIP has generic monitor mapped with it. However, I need different monitor for orginal_pool (used by app1)
please suggest.
Hello there,
Can you give this rule a try?
pool original_pool
when LB_FAILED {
if { [active_members http_pool] == 0 } {
log local0. “Pool [LB::server pool] has an active mbrs = [active_members [LB::server pool]]”
pool fall_back_pool
log local0. “Page went to Fallback pool”
persist none
LB::reselect
hope that helps..
Thank you. I would check this and reply back.
