I am very weak at irules and appreciate any help. The logic is: If (http request) does NOT include a trailing / in url https://beta.example.com/BOE/BI then stop the traffic. Else Continue
Is there an option to use a “not end with”? Something like the below?
when HTTP_REQUEST { if { ( [string tolower [HTTP::path]] not end with “/” ) } { TCP::close } }
Hi, It’s easy as you can see:
if { not ( [HTTP::path] ends_with "/" ) } {
reject
I changed it to “reject” because sounds better to me, ok?
As a tip of mine, when do you need to find commands here on DC, try to search those words plus wiki e.g. “not wiki”, “TCP::close wiki”, “operators wiki”, “reject wiki” and you be saved.
Best regards.
