Hi all,
I just made a rule for to redirects and it works 100%. but Im not sure if I can make it so its not case sensitive? so it would also answer for /Desktop or /DeskTop
if { [HTTP::uri] eq “/desktop” } {
HTTP::redirect “http://www.google.com/Solutions/Desktop/tabid/122/Default.aspx”
if { [HTTP::uri] eq “/trial” } {
HTTP::redirect “http://www.google.com/Trial/tabid/121/Default.aspx”
thanks for any help.
Yah I had see that “string tolower” command but wasnt clear on its total use. I thought it was for moving from all upper case to lower case or at least that was the examples I had see posted.
anyways thanks again
Ryan
It is for moving everything to lowercase.
By changing the string you’re inspecting completely to lowercase before the comparison is made, you can ensure that case has no relevance in your comparison. Does that make sense?
Colin
ok, now I get it. thanks for the explanation
Ryan
No sweat, glad I could help. Let us know if you’ve got any more questions.
Colin
