urgent: need help for regular expression ?
Hi, all
Sorry , I am on site , can anybody help to create one line simple iRule to get the FQDN from the below sip string ?
ECSCF-Simulator7.P-LRF.com;lr>
Route: ECSCF-Simulator7.P-LRF.com;lr>
Contact: sip.test-site2.ERICSSON2.com:5060>
the fqdn is after “sip:” and “@” (if exist") and before “:” or “;”
I want to set the fqdn to one value and do dns query for this domain name , and then change change the destination ip to be that address.
Thanks.
Raymond
Hi Raymond,
Can you post the input sample in [ code ] [/ code ] blocks without the spaces?
Here’s a related post you can reference as well:
Thanks, Aaron
Route:
Contact:
I want get the FQDN out of the SIP header string , like “sip.test-site2.ERICSSON2.com” and “ECSCF-Simulator7.P-LRF.com” . Thanks.
Can you post a few more examples of the two different header values?
Are you able to parse the route and contact headers using separate logic?
Here’s a first stab at a combined regex that matches the domain of both examples you’ve shown:
Aaron
Sure I can using separate logic for Route and contact , actually my question is focus the FQDN may or may not have “@” .
Contact:
Contact:
Contact:
Contact:
these is four examples , can I get the sip.test-site2.ericsson2.com with same regex ?
The last regex didn’t render correctly. And as TCL advanced regexes don’t support lookbehinds, the regex won’t work. You can do two scan commands for this though:
when RULE_INIT {
 Loop through some test strings:
foreach str [list
 Scan assuming a format of
