Hi..
Thanks for the suggestions but both have been tried but nothing I can see that is really telling me what the issue is..
Here are some logs and the result of load config:
[root@F5BIGIP02:INOPERATIVE:] config # tmsh load sys config verify
Validating system configuration…
/defaults/asm_base.conf
/defaults/config_base.conf
/defaults/ipfix_ie_base.conf
/defaults/ipfix_ie_f5base.conf
/defaults/low_profile_base.conf
/defaults/low_security_base.conf
/defaults/policy_base.conf
/defaults/wam_base.conf
/defaults/analytics_base.conf
/defaults/apm_base.conf
/defaults/apm_oauth_base.conf
/defaults/apm_saml_base.conf
/defaults/app_template_base.conf
/defaults/classification_base.conf
/var/libdata/dpi/conf/classification_update.conf
/defaults/ips_base.conf
/var/libdata/ips/ips_update.conf
/defaults/daemon.conf
/defaults/pem_base.conf
/defaults/profile_base.conf
/defaults/sandbox_base.conf
/defaults/security_base.conf
/defaults/urldb_base.conf
/usr/share/monitors/base_monitors.conf
/defaults/cipher.conf
/defaults/ilx_base.conf
Validating configuration…
Loading schema version: 14.1.0.3
/config/bigip_base.conf
/config/bigip_user.conf
/config/bigip.conf
/config/bigip_script.conf
Loading schema version: 15.0.1
ep 29 14:38:20 F5BIGIP02.home.local warning tmsh[6183]: 01420013:4: [api-status-warning] pem/protocol/profile/gx is deprecated
Sep 29 14:38:20 F5BIGIP02.home.local warning tmsh[6183]: 01420013:4: Per-invocation log rate exceeded; throttling.
Sep 29 14:38:21 F5BIGIP02.home.local notice tmsh[6183]: 01420012:5: Loading schema version: 14.1.0.3
Sep 29 14:38:22 F5BIGIP02.home.local info tmsh[6183]: cli schema (14.1.0.3) has been loaded from schema data files.
Sep 29 14:38:23 F5BIGIP02.home.local notice tmsh[6183]: 01420012:5: Loading schema version: 15.0.1
Sep 29 14:38:23 F5BIGIP02.home.local notice mcpd[6366]: 01071038:5: Loading keys from the file.
Sep 29 14:38:23 F5BIGIP02.home.local notice mcpd[6366]: 01071038:5: Unit key hash from key header: 6f:f8:31:26:25:ea:4e:3a:1f:d3:1d:57:36:d5:13:f8:64:0c:00:b1
Sep 29 14:38:23 F5BIGIP02.home.local notice mcpd[6366]: 01071038:5: Unit key hash computed from read key:6f:f8:31:26:25:ea:4e:3a:1f:d3:1d:57:36:d5:13:f8:64:0c:00:b1
Sep 29 14:38:25 F5BIGIP02.home.local notice sod[6837]: 010c0063:5: Waiting for Mcpd without a response. Try again…
Sep 29 14:38:25 F5BIGIP02.home.local notice mcpd[6366]: 01390002:5: The size of the configuration DB has been extended by 5159040 bytes, now using a total of 26130560 bytes
Sep 29 14:38:26 F5BIGIP02.home.local notice mcpd[6366]: 01390002:5: The size of the configuration DB has been extended by 5159040 bytes, now using a total of 31289600 bytes
Sep 29 14:38:26 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: scheduling datasync_renew_conf because device was added: device_name /Common/F5BIGIP01.home.local is_self_device 0
Sep 29 14:38:26 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: scheduling datasync_renew_conf because device was added: device_name /Common/F5BIGIP02.home.local is_self_device 1
Sep 29 14:38:33 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: created datasync device-stats objects for tables [ CRYPT_ASM_DOSL7 CRYPT_FPM CS_ASM_DOSL7 CS_FPM STATIC_FPM RSA CAPTCHA CS_PERM_FPM ]
Sep 29 14:38:33 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: scheduling datasync_renew_conf because global device-group /Common/datasync-global-dg was updated during config load
Sep 29 14:38:33 F5BIGIP02.home.local notice mcpd[6366]: 010719e7:5: Virtual Address /Common/1.1.1.1 general status changed from BLUE to RED.
Sep 29 14:38:35 F5BIGIP02.home.local notice mcpd[6366]: 01390002:5: The size of the configuration DB has been extended by 5159040 bytes, now using a total of 36448640 bytes
Sep 29 14:38:36 F5BIGIP02.home.local err mcpd[6366]: 01070734:3: Resuming log processing at this invocation; held 31 messages.
Sep 29 14:38:36 F5BIGIP02.home.local err mcpd[6366]: 01070734:3: Configuration error: MCPProcessor::check_initialization: The input string contains invalid characters
Sep 29 14:38:36 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-457.0.iso_50620_1) dst (/shared/apm/images/epsec-1.0.0-457.0.iso)
Sep 29 14:38:38 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-489.0.iso_52663_1) dst (/shared/apm/images/epsec-1.0.0-489.0.iso)
Sep 29 14:38:41 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-718.0.iso_65092_1) dst (/shared/apm/images/epsec-1.0.0-718.0.iso)
Sep 29 14:38:55 F5BIGIP02.home.local notice sod[6837]: 010c0063:5: Waiting for Mcpd without a response. Try again…
Sep 29 14:38:56 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-753.0.iso_65225_1) dst (/shared/apm/images/epsec-1.0.0-753.0.iso)
Sep 29 14:39:11 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-787.0.iso_69633_1) dst (/shared/apm/images/epsec-1.0.0-787.0.iso)
Sep 29 14:39:25 F5BIGIP02.home.local notice sod[6837]: 010c0063:5: Waiting for Mcpd without a response. Try again…
Sep 29 14:39:25 F5BIGIP02.home.local notice sod[6837]: 010c0064:5: Waiting for Mcpd without a response. Happened 5 times. Reconnect.
Sep 29 14:39:29 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-804.0.iso_74218_1) dst (/shared/apm/images/epsec-1.0.0-804.0.iso)
Sep 29 14:39:45 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: copy_file: EPSEC in EspecFileObjMgr::copy_file - src (/config/filestore/files_d/Common_d/epsec_package_d/:Common:epsec-1.0.0-810.0.iso_74147_1) dst (/shared/apm/images/epsec-1.0.0-810.0.iso)
Sep 29 14:40:05 F5BIGIP02.home.local notice mcpd[6366]: 0107165d:5: init_system_epsec_software_status: EPSEC:: loading of Epsec software status passed
Sep 29 14:40:06 F5BIGIP02.home.local err mcpd[6366]: 01070734:3: Configuration error: MCPProcessor::check_initialization: The input string contains invalid characters
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 01070406:5: Removed publication with publisher id ha_table_publish
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: renewing datasync configuration
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: Initializing datasync configuration for provisioned modules [ none ]
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: created initial datasync global profiles for tables [ CRYPT_ASM_DOSL7 CRYPT_FPM CS_ASM_DOSL7 CS_FPM STATIC_FPM RSA CAPTCHA CS_PERM_FPM ] with activation_epoch 1569764406
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: created datasync device-stats objects for tables [ CRYPT_ASM_DOSL7 CRYPT_FPM CS_ASM_DOSL7 CS_FPM STATIC_FPM RSA CAPTCHA CS_PERM_FPM ]
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 010718ed:5: DATASYNC: Done initializing datasync configuration for provisioned modules [ none ]
Sep 29 14:40:06 F5BIGIP02.home.local err mcpd[6366]: 01070734:3: Per-invocation log rate exceeded; throttling.
Sep 29 14:40:06 F5BIGIP02.home.local notice mcpd[6366]: 01070404:5: Add a new Publication for publisherID ha_table_publish and filterType 4194304
Sep 29 14:40:36 F5BIGIP02.home.local notice sod[6837]: 010c0063:5: Waiting for Mcpd without a response. Try again…
Sep 29 14:41:01 F5BIGIP02.home.local warning diskmonitor[6228]: 011d0002:4: Cannot access the database because mcpd is not running.
Sep 29 14:41:06 F5BIGIP02.home.local notice sod[6837]: 010c0063:5: Waiting for Mcpd without a response. Try again…
