What are the ways to upgrade F5. When I tried to upgrade using system/Software management, I get an error while processing the request. What are the other ways to update.
Please make sure re-active licence before install software on new volume,once reboot OS on new volume..normally it should works fine..
what error you got?
Thx
Srini
error while importing OS or while you installing it … here is the way to upgrade VE
if you have error while you import OS check your disk space.
