Upgrade to v13.1 and I get a loss of functionality
I have just tried to upgrade our test boxes from 12.1.2 to v 13.1 After booting into the partition with the 13.1 image on, and doing a reboot, I get this difference
That is 12.1.2
and that is 13.1
When I first attempted to boot from 13.1, I checked the drop down that has copy config. I copied the config from 12.1.2
Is this a bug?
Greetings,
The SSL certificate list has moved in the GUI from System → File Management to System → Certificate Management → Traffic Certificate Management. See the following K article for more information.
Cheers
Oh sweet lord!!!
How stupid do I feel!!
I used to be L3 Support for a very well known enterprise financial tool .. people like me who didnt RTFM used to drive me crazy!!!
Im going to slink away, ashamed, now and maybe find a box to hide in ..
Thank you very much
It is a question very well put together, though. :slight_smile:
It is very hard to figure out what is needed with many other questions here.
No doubt others will benefit from you having posed the question. The change threw me for a loop, also, the first time I encountered it. :slight_smile:
