Upgrade to 11.2.0 Active and Passive
Everything was working perfectly after upgrade but later on GUI is inaccessible no error only shows “redirect” on Active box whereas passive is working without error.
Hello,
Tryto connect in cli or ssh to see the state of your active device. You probably have an issue with a process, I think of mcpd process that fails. Then, I suggest to check ltm logs in /var/log folder
Maybe, you have the root partition full.
