Upgrade Q - 1600 GTM from 9.4x to 10.2
Seeing the error as below when running the image2disk utility:
error: status 8192 returned by command: mount -o loop /shared/images/BIGIP-10.2.0.1707.0.iso /mnt/tm_install/4268.iBdUDb
info: ++++ result:
info: mount: Not a directory
info: ----
Failure testing installer update status in /shared/images/BIGIP-10.2.0.1707.0.iso.
Any experiences with this and known resolutions?
A few stabs in the dark:
Make sure that the ISO is in /shared/images. Verify the md5sum of the ISO matches the .md5 file: md5sum /shared/images/*.iso; cat *.md5. Make sure you’re logging into the serial console as root.
If those steps don’t show a problem, you can open a case with F5 Support.
Aaron
Thanks Aaron,
All above checks done successfully - I will get a case opened.
Rich
This is a known issue. The installer just didn’t have a good way of letting you know the MD5 of that iso file was bad. Copy it back to the directory and try again. Did it end up working?
