Upgrade FT LTMs Active Standby from 11.3 to 11.4.1
Is this worth the minor upgrade? Is there a user guide out there to follow? Thanks.
Upgrades are generally worth it if you need a new feature or major bugfix available in a new version of code. If there’s nothing driving the need to upgrade, then it may not be worth your time.
Thanks for responding @Cory, do you have a recommended user guide I can follow? I see the 10.x to 11.x, but what about minor ones from 11.3-11.4
None that I’m aware of. v10 to v11 was a big jump, so there was a need for upgrade recommendations. The major difference between v11.3 and v11.4 is the introduction of local traffic policies vs. HTTP classes. If you aren’t using HTTP classes, then your upgrade should be fairly seamless.
Thanks for responding Cory, I appreciate it.
