Hi All,
We have a F5 in our environment and we want to upgrade from currently running v12.1.2 but little confused which version will be the best and stable as of now? Can someone suggest a document or anything.
Thanks..
Hi All,
Thanks..
In version 12.x, the last stable version is 12.1.4.1
REF : myF5
The best stable is the point release, check the version Schema Definitions
Thanks Lidev,
I have a point here, what will be upgrade path if I have to upgrade to 12.1.4.1. and any stable version in 14.x if so kindly suggest the upgrade path.
Thanks again in advance..
issue already discussed on Devcentral
, take on look on theses links below :
