upgrade from ltm 10.2.3 to 11.2.0 fails to load config
Hello anyone seeing this issue I upgraded as I have done many times before off the same version however going to a major version seems to have issues, has anyone done this?
Heres my attempt to load the config
[root@test-f5:Active:Standalone] config tmsh load /sys ucs /config-test-f5.ucs
Saving active configuration…
Current configuration backed up to /var/local/ucs/cs_backup.ucs.
Product : BIG-IP
Platform: Mercury
Version : UCS : 10.2.3
System: 11.2.0
Hostname: test-f5.foo.com
Installing --full-- configuration on host test-f5.foo.com
Installing configuration…
Installing the license file…
ATTENTION REQUIRED:
Your previous configuration files have been archived, as listed
below. If you customized any settings in these files before
upgrading, you will need to manually restore those changes by
using the Configuration utility or Traffic Management Shell (tmsh).
Archiving /config/wa/pvsystem.dtd.10.2.3
Archiving /config/wa/pvsystem.conf.10.2.3
Archiving /config/wa/globalfragment.xml.10.2.3
Archiving /config/wa/transforms/common.zip.10.2.3
Post-processing…
Reloading License and configuration - this may take a few minutes…
Jul 24 17:00:30 test-f5 emerg mcpd[6097]: 0107070e:0: Software version not covered by service agreement. Reactivate license before continuing.
Jul 24 17:00:30 test-f5 emerg mcpd[6097]: 01070608:0: License is not operational (expired or digital signature does not match contents).
Configuration loading error: base-config-load-failed
For additional details, please see messages in /var/log/ltm
WARNING: There were one or more errors detected during installation.
Check the error messages and take the proper actions if needed.
ERROR: UCS installation failed.
Operation aborted.
/tmp/configsync.spec: Error installing package
Config install aborted.
Unexpected Error: UCS loading process failed.
I reactivated the license then each time I run the config it does the same thing & I have to reactivate it as well but none of the config is imported, my license is valid
Can you reactivate the license on the original 10.2.3 slot and then perform the upgrade. If the config load fails, you can run ‘/usr/libexec/bigpipe daol’, resolve any config file issues and then run ‘/usr/libexec/bigpipe daol’ again.
Aaron
Thanks, I went through support for this as well and found that in version 11.x it actually attempts to validate some of the netmasks that may be in its configs in our case it was an improper netmask in a datagroup assoc w an irule
