Upgrade 11.4 to 12.1
Hi Guys, I am planning to upgrade my F5s (LTM & ASM ) from 11.2 to 12.1, Are there any recommendations or known issue.
I’d read the Release Notes for v11.6.1, v12.1, and v13.0 to see what issues are fixed in which release and if there is anything that would affect you but currently isn’t.
Dear,
If you have access to , upload the Qkview and check for Upgrade Advisory. Its very good feature to have a look on known issues before going for an upgrade.
Regards,
Mohammed Shiraz
