Upgrade 11.4.1 to 11.6. hf1
Hi, I tried to upgrade a bigip 7200 box from 11.4.1 to 11.6.0 and have no success. The system was inoperative and I received messages about config fails and license expired. anyone had this problem? I do not find anything in the release notes on some step forward.
Have you checked the service check date of your license. It has to be later than the release date of new software. If not you simply reactivate your license to update the service check date. This does however require a valid service contract with F5.
I’ll check this out, thank you so much.
Had the same issue. Updated our license file with F5 and the upgrade succeeded.
