Hello.
I’m trying to add a new datagroup record, to do so I use next code:
from f5.bigip import ManagementRoot
session = ManagementRoot("10.1.1.1","admin","mypass",token=True)
datagroup = session.tm.ltm.data_group.internals.internal.load(name='test', partition='Common')
datagroup.records = ["4.4.4.4/32", "4.4.4.5/32"]
datagroup.update()
print(datagroup.records)
Having next result:
[{'name': '4.4.4.4/32', 'data': ''}, {'name': '4.4.4.5/32', 'data': ''}]
This is OK for updating address datagroups, but now I’m trying to modify strings datagroups with name and data fields. Do you know how should I write the variable in this case?
I can do it using REST without problem, but not using SDK. Any idea?
PUT https://localhost/mgmt/tm/ltm/data-group/internal/~Common~test
Header: "Content-type: application/json"
Payload: '{"records": [{"name": "mydomain1","data": "4.4.4.4/32"}, {"name": "mydomain2","data": "4.4.4.5/32"}]}'
Thanks in advance.
KR, Dario.
