Updated iAPP for Lync 2010
Hi i was looking for the updated iApp template for Lync 2010, should´nt the template be under the DevCentral - An F5 Technical Community under F5 supported iApp templates ?
/regards Craig
Hi Craig, the updated Lync iApp is now on the code share page under “F5 Contributed”.
thanks
Mike
In the 3-15 release notes it states SSL and other profiles were removed for access services. Is there a reason for this? Previous versions has SSL profile (and SSL termination) enabled in the iApp.
- b
The SSL and HTTP profiles were removed because although you can provision it on port 443, the Access service does not use HTTP. The previous version of the template was breaking access by applying these profiles to the virtual server.
