Update External Datagroups
Problem this snippet solves:
This snippet allows users to add/update external data groups.
How to use this snippet:
The external data groups must be uploaded via scp (or pasted into files) before this code will work.
Code :
# the data file must be transferred to the target LTM via scp or something similar
# the file name and full path must match DG_SRC
import requests, json
# define program-wide variables
BIGIP_ADDRESS = '192.168.1.41'
BIGIP_USER = 'admin'
BIGIP_PASS = 'admin'
DG_FILE = 'Data'
DG_SRC1 = 'file:/var/tmp/PreviousData.txt'
DG_TYPE = 'string'
EXT_DG_NAME = 'Data'
DG_SRC2 = 'file:/var/tmp/CurrentData.txt'
# get data-group info
def get_dg(bigip):
        r = bigip.get('%s/ltm/data-group' % BIGIP_URL_BASE)
        print json.dumps(r.json())
def create_sys_file(bigip):
        payload = {}
        payload['name'] = DG_FILE
        payload['separator'] = ':='
        payload['sourcePath'] = DG_SRC1
        payload['type'] = DG_TYPE
        print json.dumps(payload)
        r = bigip.post('%s/sys/file/data-group' % BIGIP_URL_BASE, data=json.dumps(payload))
def create_ext_dg(bigip):
        payload = {}
        payload['name'] = EXT_DG_NAME
        payload['externalFileName'] = '/Common/%s' % DG_FILE
        r = bigip.post('%s/ltm/data-group/external' % BIGIP_URL_BASE, data=json.dumps(payload))
def update_sys_file(bigip):
        payload = {}
        payload['sourcePath'] = DG_SRC2
        r = bigip.put('%s/sys/file/data-group/%s' % (BIGIP_URL_BASE, DG_FILE), data=json.dumps(payload))
def update_ext_dg(bigip):
        payload = {}
        r = bigip.put('%s/ltm/data-group/external/%s' % (BIGIP_URL_BASE, DG_FILE), data=json.dumps(payload))
def save_config(bigip):
        payload = {}
        payload['command'] = 'save'
        r = bigip.post('%s/sys/config' % BIGIP_URL_BASE, data=json.dumps(payload))
# REST resource for BIG-IP that all other requests will use
bigip = requests.session()
bigip.auth = (BIGIP_USER, BIGIP_PASS)
bigip.verify = False
bigip.headers.update({'Content-Type' : 'application/json'})
print "created REST resource for BIG-IP at %s..." % BIGIP_ADDRESS
# Requests requires a full URL to be sent as arg for every request, define base URL globally here
BIGIP_URL_BASE = 'https://%s/mgmt/tm' % BIGIP_ADDRESS
# get data info
get_dg(bigip)
print "got data group info"
print "created sys file for external data group"
print "created external data group"
print "updated sys file for external data group"
print "updated external data group"
save_config(bigip)
print "saved config"
Tested this on version:
11.5
contributed by Pat Chang
