Hello All. I’d appreciate some help debugging an issue with new device certificates, and communication between two of our f5s.
We replaced the certs under Device Certificate Management, and each server has the full chain for both servers under Device Trust Certificates. The message we see in the logs is:
Mar 16 10:34:53 s0711125-mgmt iqmgmt_ssl_connect: SSL error:14094413:SSL routines:SSL3_READ_BYTES:sslv3 alert unsupported certificate
(Note that this is the full line. In searching for similar cases on here I found a lot of cases where the log entry was “unsupported certificate purpose”, but that is not the case here. I tried turning the SSL logging up to debug, and got no additional information that I can see.)
In a packet trace I can see that the response is indeed a TLSv1.2 Alert: Unsupported Certificate response:
2447 0.284021 me partner TLSv1.2 84 OUT s1/tmm3 : Alert (Level: Fatal, Description: Unsupported Certificate)
The (redacted) cert that my partner presented looked like:
Certificate:
signedCertificate
version: v3 (2)
serialNumber:
signature (sha256WithRSAEncryption)
Algorithm Id: 1.2.840.113549.1.1.11 (sha256WithRSAEncryption)
issuer: rdnSequence (0)
validity
subject: rdnSequence (0)
subjectPublicKeyInfo
extensions: 9 items
Extension (id-ce-subjectAltName)
Extension (id-ce-subjectKeyIdentifier)
Extension (id-ce-authorityKeyIdentifier)
Extension (id-ce-cRLDistributionPoints)
Extension (id-pe-authorityInfoAccess)
Extension (id-ce-keyUsage)
Extension Id: 2.5.29.15 (id-ce-keyUsage)
Padding: 5
KeyUsage: a0
1... .... = digitalSignature: True
.0.. .... = contentCommitment: False
..1. .... = keyEncipherment: True
...0 .... = dataEncipherment: False
.... 0... = keyAgreement: False
.... .0.. = keyCertSign: False
.... ..0. = cRLSign: False
.... ...0 = encipherOnly: False
0... .... = decipherOnly: False
Extension (id-ms-certificate-template)
Extension Id: 1.3.6.1.4.1.311.21.7 (id-ms-certificate-template)
CertificateTemplate
templateID: 1.3.6.1.4.1.311.21.8.14764644.7141585.13978757.4163610.14474613.168.14047150.174214 (iso.3.6.1.4.1.311.21.8.14764644.7141585.13978757.4163610.14474613.168.14047150.174214)
templateMajorVersion: 100
templateMinorVersion: 14
Extension (id-ce-extKeyUsage)
Extension Id: 2.5.29.37 (id-ce-extKeyUsage)
KeyPurposeIDs: 1 item
KeyPurposeId: 1.3.6.1.5.5.7.3.1 (id-kp-serverAuth)
Extension (id-ms-application-certificate-policies)
Extension Id: 1.3.6.1.4.1.311.21.10 (id-ms-application-certificate-policies)
CertificatePoliciesSyntax: 1 item
PolicyInformation
policyIdentifier: 1.3.6.1.5.5.7.3.1 (id-kp-serverAuth)
algorithmIdentifier (sha256WithRSAEncryption)
Padding: 0
Any thoughts on what might be causing this error?
Thanks much for any help,
- rob.
