Unsuccessful Installation
Hi
I’ve installed MSSQL2005 SP2 (incl. Reporting), IIS and SCOM2007 on a W2K3-SP2-Server. The “F5 Monitoring Service” is running under a explicit F5-Account, which has local administrators-rights.
I tried to install the F5-MgmtPack, but it always fails:
The Mmgt-Pack-“setup.log” shows the follwing fatal-error:
<03-26-2010 09:25:13> Info: HealthService service state is: Running
<03-26-2010 09:25:13> Info: Stopping service: HealthService
<03-26-2010 09:25:15> Info: HealthService service has been stopped.
<03-26-2010 09:25:15> Info: HealthService service state is: Stopped
<03-26-2010 09:25:15> Info: Starting service: HealthService
<03-26-2010 09:25:20> Info: HealthService service has been started.
<03-26-2010 10:16:55> Info: Licensing of F5 Networks Management Pack has completed successfully.
<03-26-2010 10:16:55> Info: Verifying the DataSource and ConditionDetection modules required for the F5 Monitoring Service to run are loaded by Operations Manager monitoring host.
<03-26-2010 10:16:57> Info: DataSource and ConditionDetection modules successfully loaded by Operations Manager monitoring host.
<03-26-2010 10:16:57> Info: F5MonitoringService service state is: Stopped
<03-26-2010 10:16:57> Info: Starting service: F5MonitoringService
<03-26-2010 10:17:01> Info: F5MonitoringService service has been started.
<03-26-2010 10:17:01> Info: F5MonitoringService is starting up.
<03-26-2010 10:41:33> FatalError: The F5 Monitoring Service did not start within the timeout period.
<03-26-2010 10:41:33> FatalError: There was a problem attempting to make calls into the F5 Monitoring Service. Check the Windows Event Log and trace logs for the reason and try starting the service again manually.
In the system-eventlog, I have the following warnings:
Unexpected SQL failure: Invalid object name ‘DynamicData.Entity’.
For more information, see Help and Support Center at Microsoft Support.
Unable to initialize data storage: Unexpected SQL failure: Invalid object name ‘DynamicData.Entity’.
Detailed Exception Information:
F5Networks.F5Exception: Unable to initialize data storage: Unexpected SQL failure: Invalid object name ‘DynamicData.Entity’. ---> F5Networks.ManagementPack.DataAccess.NonfatalDataAccessException: Unexpected SQL failure: Invalid object name ‘DynamicData.Entity’. ---> System.Data.SqlClient.SqlException: Invalid object name ‘DynamicData.Entity’.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader()
at F5Networks.ManagementPack.DataAccess.SqlServer.SqlConfigAdapter.<>c__DisplayClassbf.<_LoadEntityInfoCache>b__bc()
at F5Networks.ManagementPack.DataAccess.ManagedConnections.ConnectionPoolBase`2.<>c__DisplayClass6.b__5()
at F5Networks.ManagementPack.DataAccess.ManagedConnections.ConnectionPoolBase`2.CoreDoOperation[TReturnResult](GenericVoidHandler`1 operation)
at F5Networks.ManagementPack.DataAccess.SqlServer.SqlConnectionPool.CoreDoOperationWithExceptionMapping[TReturnResult](ManagedSqlConnection connection, GenericVoidHandler`1 operation)
--- End of inner exception stack trace ---
at F5Networks.ManagementPack.DataAccess.ManagedConnections.ConnectionPoolBase`2.<>c__DisplayClass9`1.b__8()
at F5Networks.ManagementPack.DataAccess.ManagedConnections.ManagedConnectionBase`1.DoOperationWithRecovery[TReturnResult](GenericVoidHandler`1 operation)
at F5Networks.ManagementPack.DataAccess.ManagedConnections.ConnectionPoolBase`2.UseConnectionForOperation[TReturnResult](TManagedConnectionType& connection, Object connectionTag, GenericVoidHandler`1 operation)
at F5Networks.ManagementPack.DataAccess.ManagedConnections.ConnectionPoolBase`2.UseConnectionForOperation(TManagedConnectionType& connection, Object connectionTag, VoidVoidDelegate operation)
at F5Networks.ManagementPack.DataAccess.ManagedConnections.LockedConnectionPoolReference`2.UseConnection(VoidVoidDelegate operation)
at F5Networks.ManagementPack.DataAccess.SqlServer.SqlConfigAdapter._LoadEntityInfoCache()
at F5Networks.ManagementPack.DataAccess.SqlServer.SqlConfigAdapter._Initialize()
at F5Networks.ManagementPack.DataAccess.SqlServer.SqlConfigAdapter._EnsureInitialized()
at F5Networks.ManagementPack.DataAccess.SqlServer.SqlConfigAdapter.Initialize()
at F5Networks.ManagementPack.DataAccess.Configuration.ConfigManager`8._Initialize()
at F5Networks.ManagementPack.DataAccess.Configuration.ConfigManager`8..ctor(ConfigAdapterBase`4 configAdapter, MonitoringAdapterBase`4 monitoringAdapter)
at F5Networks.ManagementPack.Services.DeviceMonitor._CreateConfigurationManager(MonitoringAdapterBase`4 operationsManagerConfigurationAdapter, ConfigAdapterBase`4 sqlConfigurationAdapter)
at F5Networks.ManagementPack.Services.DeviceMonitor._InitializeDataStore()
Any hints? I have also reinstalled the whole system, but → no success.
Every 10 seconds, the F5-Monitoring-Service is started, stopped, started, stopped…and so on.
Thanks a lot.
Tom
It sound like there may be a problem with the F5 database. Could you please verify that the database looks correct?
1. Verify that the F5 service has the correct connection information for the database:
a) Open the F5 service configuration file (C:\Program Files\F5 Networks\Management Pack\f5mpsvc.exe.config)
b) The value specified for “SQLHostName” should match your SQL Server host name
c) The value specified for “DatabaseName” should match a database in the above SQL Server instance
2. Open the database specified in the config file and verify that the “DynamicData.Entity” table exists:
a) Open SQL Server Management Studio
b) Connect to your SQL Server instance
c) Expand the list on the left to Databases => F5_ManagementPack => Tables
d) Verify that there is a table named “DynamicData.Entity”
If the database and/or table is missing, something probably went wrong in the installation process and we can diagnose further.
Hi
My “f5mpsvc.exe.config”-File looks like this:
Within the installation of the MgmtPack, there was no sql-database “F5_ManagementPack” created. The only one I see in the SQL-Studio is the “OperationsManager”-database. The server, which is defined in the attribute “SQLHostName” is properly resolvable → no name-resolution-issue. I had created a Active-Directory-User with administrative rights on the “F5-Management-Pack”-Server and also full db-rights on the sql-server (same box). During the installation, I was asked for this f5-user. There I entered this active-directory-f5-user (full privileges).
Is there a way to initiate the db-creation step again? Or can I just add the missing table? I logged in also with the f5-user and started the “F5Networks.ManagementPack.Setup.exe” again. There I was able to click the option “Repair” → but no success.
I have also created the database “F5_ManagementPack” manually and repaired the installation → also no success. In the windows-eventlog is still the same error:
Unable to initialize data storage: Unexpected SQL failure: Invalid object name 'DynamicData.Entity'.
  F5Networks.F5Exception: Unable to initialize data storage: Unexpected SQL failure: Invalid object name 'DynamicData.Entity'. ---> F5Networks.ManagementPack.DataAccess.NonfatalDataAccessException: Unexpected SQL failure: Invalid object name 'DynamicData.Entity'. ---> System.Data.SqlClient.SqlException: Invalid object name 'DynamicData.Entity'.
Thanks a lot for your help.
Kind regards,
Tom
Tom,
If you run setup and it does not correctly create the database, there should be an error like "Unable to create database: … " in the setup log with details as to the cause of the failure.
I can give you a much better diagnosis if you can send your setup log (send directly to ManagementPack@f5.com if you would rather not post here). Ideally, first delete your F5_ManagementPack database and then re-run setup so I can determine why the DB is not being created correctly in the first place.
