Seems that this is a simple thing. Right now I have a client-ssl profile that looks like the below. How can I use a tmsh command to unset or make it so the ciphers are assumed from the parent profile?
ltm profile client-ssl testblah { ciphers ALL:!SSLv2:!SSLv3 defaults-from my_parent_ssl_profile }
tmsh modify ltm profile client-ssl testblah ciphers none
yep . you are right. why can’t we delete and create the clientssl profile again ?
Seems like a feature request. Similar question was posted on RestAPI.
May be can try following. Not exactly what is required.
tmsh list ltm profile client-ssl my_parent_ssl_profile ciphers \ | awk '/ciphers/{print $2}' \ | xargs -I{} tmsh modify ltm profile client-ssl testblah ciphers '{}'
