unresponsive devices
Hello team,
I am looking for monitor setup to alert when the HA pair going to unresponsive. ex: if both devices are active- active urls will be down. can we monitor this situation.
When there is a change of HA status, there will be log created and SNMP traps sent. You just need to configure the system to send the logs to a remote server, and monitor the remote server for this type of alerts.
However, if unresponsible = busy, you should not get an active/active situation. Make sure you have both a TMM and management configured in the network failover.
This solution has the explanation:
