As AI agents proliferate and collaborate across complex workflows, the challenge of sharing context and coordinating actions between autonomous agents has only grown more acute. The traditional, manual approach to data integration and context propagation is no longer viable in today’s fast-moving, multi-agent ecosystems. Agent2Agent Protocol (A2A) is a newly introduced standard designed to revolutionize agent-to-agent communication and cross-agent context sharing. Released by Google in April 2025 and now experimentally supported starting with F5 BIG-IP v21.1. This protocol will be further enhanced in the upcoming BIG-IP versions.
In this article, we will explore the foundational concepts behind A2A, its importance to customers and AI systems, how F5’s BIG-IP supports and enhances A2A functionality, and what you will experience in the demo video that is linked in this article below. By the end of this article, you will understand why A2A is a critical enabler for AI workloads and how F5 BIG-IP ensures its seamless integration into your digital ecosystem.
This article focuses on agents communicating using A2A , which align with the F5 AI Reference Architecture components and the insertion point, as shown below:
What Is A2A?
- A2A, or Agent2Agent, is an open protocol designed to enable AI agents to communicate, coordinate, and collaborate across vendor and framework boundaries. It addresses fragmentation in the agent ecosystem by providing a standardized way for agents to interact, exchange context, and coordinate actions on top of diverse enterprise platforms.
- Core capabilities at a high level:
- Capability discovery: Agents advertise what they can do (via an Agent Card in JSON) so clients can select the right partner to handle a task.
- Task management and lifecycle: Interactions are oriented around end-to-end tasks, which may complete quickly or require long-running collaboration. Tasks produce artifacts as outputs.
- Collaboration and context sharing: Agents exchange messages containing context, artifacts, and instructions to stay aligned on progress.
- User experience negotiation: Messages include parts (full content units with content-type and UI negotiation details such as support for images, video, iframes, web forms, etc.).
- Modality agnosticism and long-running support: A2A supports multiple modalities (text, audio, video) and long-running workflows with real-time feedback and state updates.
- Design goals emphasize openness, interoperability, and security, built on widely used web standards to simplify integration with existing IT stacks.
Why Is A2A Relevant to Customers?
- Interoperability across a fragmented agent landscape: As enterprises deploy AI agents from multiple vendors, A2A provides a common protocol layer that enables agents to talk to one another, reducing integration complexity and enabling richer multi-agent workflows.
- Accelerated automation of complex workflows: By enabling agents to collaborate, delegate sub-tasks, share context, and coordinate actions, customers can automate end-to-end processes that span tools, data sources, and services.
- Secure, standardized collaboration: A2A emphasizes secure by-default design with enterprise-ready authentication and authorization approaches, parity with common API authentication schemes, and robust governance during agent-to-agent interactions.
- Scalable, cross-platform AI ecosystems: A2A supports long-running tasks and real-time updates, helping organizations scale agentic AI across hybrid and multi-cloud environments and across multiple toolchains.
- Reduced integration overhead and costs: A standardized protocol minimizes bespoke integrations for each tool, lowering maintenance and total cost of ownership while improving reliability and consistency of agent interactions.
F5 BIG-IP and A2A
- F5 BIG-IP v21.1 introduces experimental support for the A2A protocol, enabling native load balancing of A2A traffic and governance capabilities through iRules-based logging and observability.
- This experimental functionality is intended for evaluation and testing, not production use, and future BIG-IP releases are expected to provide full production-level A2A support with expanded management and security features.
- The integration positions BIG-IP as a traffic management and governance layer for AI agent conversations, enabling reliable connectivity and visibility as agents from multiple ecosystems collaborate.
How Does F5 BIG-IP v21.1 Support A2A?
- Load balancing for A2A traffic: BIG-IP v21.1 can distribute A2A protocol traffic across multiple endpoints/agents, helping to maximize response times and resiliency as AI agents collaborate across services and environments.
- Governance and visibility via iRules-based logging: Administrators can define logging and monitoring rules using iRules to gain insight into A2A traffic, performance characteristics, and security events. This provides a structured way to observe agent interactions and enforce policy.
- Experimental status with future roadmap: In v21.1 the A2A integration is experimental, designed to allow evaluation and testing of how A2A traffic behaves within BIG-IP’s traffic management and security framework. F5 plans to expand management capabilities and full production support in later releases.
- Practical implications for operators:
- You can set up a BIG-IP virtual server to handle A2A endpoints and apply monitoring and governance rules to A2A traffic.
- You can leverage BIG-IP’s general traffic management capabilities (load balancing, rate limiting, security policies) to improve reliability for multi-agent workflows.
- Expect ongoing enhancements in subsequent BIG-IP releases that broaden management features, security controls, and deployment options for A2A.
Optimized Agent-to-Agent Connectivity
The introduction of experimental support for the Agent2Agent (A2A) protocol optimizes communication between AI agents, ensuring interoperability across fragmented platforms.
Features Include:
- Load balancing for A2A traffic.
- Governance via iRules based logging and visibility.
While experimental in v21.1, future releases promise full support with expanded management capabilities.
Video Demo Highlights: A2A in Action with BIG-IP v21.1**
- What you’ll see in a typical A2A demo with BIG-IP v21.1:
- Setting up a BIG-IP virtual server configured to handle A2A traffic, using the appropriate profiles to validate and manage A2A messages.
- Defining two or more A2A endpoints (agents) behind the BIG-IP VIP to demonstrate load balancing and failure scenarios.
- Enabling iRules-based logging to capture governance events, message exchanges, and artifact transfers between client and remote agents.
- Demonstrating load balancing under varying loads, including simulated agent tasks with long-running interactions, and observing how BIG-IP maintains responsiveness and visibility.
- Highlighting how A2A protocol messages (capability advertisements, task lifecycle updates, and collaboration messages) traverse the BIG-IP platform and how operators can monitor them.
- Takeaways from the demo:
- BIG-IP can provide scalable, observable, and resilient handling of A2A traffic even in an experimental stage.
- Operators gain practical governance and performance insights for multi-agent workflows as they iterate on integration designs.
- The demo showcases a concrete path from setting up A2A-enabled endpoints to achieving coordinated agent interactions through a centralized traffic management layer.
Conclusion
- A2A represents a significant step toward standardized, interoperable multi-agent ecosystems. By enabling agents to discover capabilities, manage tasks, collaborate, and negotiate user experiences, A2A unlocks powerful, cross-vendor AI automation capabilities.
- F5 BIG-IP v21.1’s experimental A2A support provides essential building blocks: load balancing of A2A traffic for reliability and governance through iRules-based logging and visibility. While not production-ready in this release, it sets the stage for broader, production-grade A2A support in future BIG-IP releases, enabling customers to confidently evaluate and design scalable AI workflows across hybrid and multi-cloud environments.
- As the A2A ecosystem evolves, BIG-IP will play a central role in delivering the performance, security, and operational control needed to realize end-to-end, cross-agent automation at scale.
Further Reading
What’s New in BIG-IP v21.1
Model Context Protocol Overview
Announcing the Agent2Agent Protocol (A2A)
