Universal Persistence
I have been reading through the LTM Advance course book and have come up to universal persistence but am having trouble understanding an option in the example in the book:
when HTTP_REQUEST { persist uie [findstr [HTTP::uri] “user=” 5 “&”] }
Im trying to understand what the ‘5’ in the persistence rule is?
they have a URI example of /env.cgi?user=123&pw456
Please any help would be much appreciated.
thanks in advance
Andreas
Hi Andreas,
You can read up on the details for findstr here:
Basically, findstr is looking in the URI for the string “user=” and then skipping five characters forward from the first character of user= and reading up to the end of the URI or to the next &. It’s trying to parse the value of the “user” parameter.
You could do this simpler using URI::query:
set user [URI::query [HTTP::uri] user]
if {$user ne ""}{
   persist uie $user
If you’re on v9 or v10, you can use a workaround for a bug in those versions:
set user [URI::query "?&[HTTP::query]" &user]
if {$user ne ""}{
   persist uie $user
Aaron
thanks Hoolio!!
