Works great with IE, but some boutique browsers append extra cookies. If the original jsession cookie does not happen to be first in the list, the LTM treats it as though it is not there, and persistence fails. I know there must be a way to force the LTM to look into the whole string.
Firefox was the only one I knew for sure. I did a tcpdump to see what was going on. We were short on time, so we worked out alternate solution. But would like to get this working, as it would be more elegant.
It worked when the cookie string looked like this:
You see the jsessionid cooke is still in there, but if not at the front, the LTM doesn’t see it. I never saw multiple jsessionid cookies, but if the whole string got inspected, I don’t think hat would hurt anything either.
As Nitass’ testing shows, HTTP::cookie should be able to parse multiple cookies in the request or response on the same header line without any issues.
Can you set up a test virtual server to continue troubleshooting this? I’d guess the issue might be a missing OneConnect profile or something else. If you’re doing L7 persistence you will need a OneConnect profile on the virtual server. Use a /0 source mask OneConnect profile if you’re using SNAT. Else, use a /32 source mask OneConnect profile if you’re not using SNAT:
Applying a OneConnect profile to the Virtual Server and checking that the jsessionID is not null, has solved the original problem. Thanks so much, both of you!
Another problem has cropped up. The application makes calls that do not have jsessionid, so I need to generate some unique (random?) to insert as a cookie. Any thoughts on the simplest way to do this?
Why not use cookie insert persistence via a profile instead of persisting on the JSESSIONID cookie with an iRule--particularly if the app doesn’t always set a JSESSIONID cookie?
You could try creating a unique ID for the cookie, persist on it and then insert the cookie in responses. But you’re basically just manually recreating what the default cookie insert persistence profile does. So why not just use that?
I think you could probably use that instead of the JSESSIONID persistence iRule. The JSESSIONID persistence iRule is only really useful if you need to persist at multiple tiers (client to web and web to app) or if clients don’t support cookies and need to use the JSESSIONID in the URIs.
This is for mobile banking. The enrollment phase requires that I grab a jsessionid from an inhouse server, and use it for persistence for the incoming client session (the one wanting to enroll). I know that is cumbersome, but that is the way the product works.
Well, I can’t say I understand the full scenario, but… here goes anyhow.
You may want to remove the spoofed JSESSIONID cookie from requests before they’re sent to the pool. You could try something like this:
if { [HTTP::cookie "JSESSIONID"] ne ""} {
Perist on the JSESSIONID or spoofed value
persist uie [HTTP::cookie "JSESSIONID"]
log local0. "[IP::client_addr] Clairmail HttpRequest. Cookies: [HTTP::header values Cookie]"
Remove spoofed cookie
if {[HTTP::cookie "JSESSIONID"] starts_with "ltm_"}{
HTTP::cookie remove "JSESSIONID"
when HTTP_RESPONSE {
Check if the app did not set a cookie
if { [HTTP::cookie "JSESSIONID"] eq ""} {
Insert a spoofed cookie in the response for persistence
set rndumb "ltm_[expr { int(100000000 * rand()) }]"
HTTP::cookie insert name "JSESSIONID" value $rndumb"
log local0. "[IP::client_addr] assigned a random cookie, $rndumb"
Add a persistence record using the random number
persist add uie $rndumb 3600
Add a persistence record using the JSESSIONID
persist add uie [HTTP::cookie "JSESSIONID"]
log local0. "[IP::client_addr] Clairmail persistence HTTP_Response. Set-Cookies: [HTTP::header values Set-Cookie]"
The second level of testing (a couple of tries with the actual application) is still looking good! Thanks so much Hoolio. It’s fun to learn new things (cookies, jseesionid, etc). One thing, I commented out the portion that removes the spoofed cookie. If this gets the program off the ground, I will urge the vendor to change thier code asap so that the mobile application supplies the cookie - I’m guessing that this current fix will be resource intensive when thousands of mobile devices are periodically calling home.
The reason I removed the spoofed cookie in HTTP_REQUEST is that I wasn’t sure what the app would do if it saw a JSESSIONID in the request which it didn’t generate. I figured it was better to not include it in the request to the pool. It wouldn’t affect the client sending that cookie in subsequent requests though.
