universal persistence mirroring
I got one concerning problem.
I create myself an iRule, attached it to a persistence profile, checked “infinity” and enabled mirroring persistence. The persistence is working as expected.
On the active LTM when running “b persist pool LB01-POOL show all”:
PERSISTENT CONNECTIONS
| Mode universal Value 0123456789
| virtual 89.151.90.10:mysql node 89.151.90.14:mysql age 1226sec
The passive shows:
No persist table entries were found.
Is that mean that the persistence is mirrored to the passive LTM, or have a problem?
M
it looks like I’m facing the same issue. Despite I’ve checked the “mirror persistence” box I cannot see the entries on the standby system. On the active system the entries are visible.
Can someone cross-check?
Thanks Otto
Thanks Otto
