I am still a bit confused on using universal persistence and the persist command. The big question is :"Can the command persist [add] uie be used in a standard iRule, or does the iRule in which the commands are used, needs to be connected to a universal persistence profile in which the iRule is connected?
persist uie
persist add uie
can be used on a standard irule or by a Universal persistence profile.
persist uie- is used in client side event (ex : HTTP_REQUEST)
- read persistence record to select pool member if record exists
- create a persistence record after member is selected
persist add uie- is used in server side event (ex : HTTP_RESPONSE)
- create a persistence record based on server response
