Universal Persistence iRule
Hello, I’m a beginner of iRule.
I want to use Universal Persistence iRule across the two virtual-servers (whose pool-member’s nodes are the same).
One virtual-server reply HTTP_RESPONSE whose Location contains the string (ticket=****).
A client sends to another virtual-server HTTP_REQUEST whose URI contains the string(ticket=***).
Those two connections must be used the same node.
I have made a iRule below, but it doesn’t work well..
What is wrong with this?
when HTTP_RESPONSE {
set ticketid [findstr [HTTP::header Location] “ticket” 7]
if { $ticketid != “” } {
persist add uie [HTTP::header $ticketid]
if { [HTTP::uri] contains $ticketid } {
persist uie [HTTP::header $ticketid]
else {
persist uie [HTTP::cookie “”]
Thanks.
not sure if i understand correctly. please feel free to revise.
[root@iris1021:Active] config b virtual bar1 list
virtual bar1 {
snat automap
pool foo
destination 172.28.17.33:http
ip protocol tcp
persist mypersist
profiles {
http {}
tcp {}
[root@iris1021:Active] config b virtual bar2 list
virtual bar2 {
snat automap
pool foo
destination 172.28.17.44:http
ip protocol tcp
persist mypersist
profiles {
http {}
tcp {}
[root@iris1021:Active] config b profile mypersist list
profile persist mypersist {
defaults from universal
mode universal
across virtuals enable
rule myrule
[root@iris1021:Active] config b rule myrule list
rule myrule {
if {$ticketid != “”} {
persist add uie $ticketid
set ticketid [URI::query [HTTP::uri] ticket]
persist uie $ticketid
[root@iris1021:Active] config curl -I http://172.28.17.33/test
HTTP/1.1 301 Moved Permanently
Date: Wed, 07 Sep 2011 13:22:48 GMT
Server: Apache/2.0.59 (rPath)
Content-Type: text/html; charset=iso-8859-1
[root@iris1021:Active] config curl -I http://172.28.17.44/?ticket=3333
HTTP/1.1 200 OK
Date: Wed, 07 Sep 2011 13:22:58 GMT
X-Powered-By: PHP/4.3.11
Set-Cookie: MyTestCookie=MyTestValue
Content-Type: text/html; charset=UTF-8
[root@iris1021:Active] config b persist show all
PERSISTENT CONNECTIONS
| Mode universal Value 3333
| virtual 172.28.17.33:http node 10.10.70.130:http age 5sec
