Unexpected traffic on F5 unable to block
We are currently receiving over 1 million active connections through our F5 from an unknown source and are trying to create an iRule or similar to block. Usually, we have 19 connections.
F5 Version: BIG-IP 9.4.8 Build 355.0 Final
From console command: bigpipe conn show all
VIRTUAL any:any ↔ NODE 203.116.13.197:http TYPE local CLIENTSIDE 100.101.24.93:26282 ↔ 203.116.13.197:http (pkts,bits) in = (1, 62) out = (0, 0)
Would anyone be able to provide an example of how to block the traffic from 203.116.13.197? This address is persistent for all of the traffic.
Thank you.
You can use iRule (examples below) or apply packet filters (under Networks) to drop packets. My preference would be for packet filter.
irule Examples:
Access Control Based On Network or Host DevCentral - An F5 Technical Community
Access Control Based on IP DevCentral - An F5 Technical Community
You may use iRule like this:
when CLIENT_ACCEPTED { if { [IP::addr [IP::client_addr] equals 10.10.10.10] } { drop log local0. “connection dropped from [IP::client_addr]” } }
All address definitions are here for your reference: DevCentral - An F5 Technical Community
