Under very low CPS, how to LB very evenly?
HI guys.
for not even LB to server, how can I do that? I`m not using persistence.
root@(MYBIGIP)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual my-vs ltm virtual my-vs { destination 50.50.50.50:http ip-protocol tcp mask 255.255.255.255 pool my-pool profiles { fastL4 { } } source 0.0.0.0/0 translate-address enabled translate-port enabled vs-index 9 } root@(MYBIGIP)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool my-pool ltm pool my-pool { load-balancing-mode least-connections-member members { 10.10.10.10:http { address 10.10.10.10 session monitor-enabled state down } 10.10.10.11:http { address 10.10.10.11 session monitor-enabled state down } 10.10.10.12:http { address 10.10.10.12 session monitor-enabled state down } 10.10.10.13:http { address 10.10.10.13 session monitor-enabled state down } 10.10.10.14:http { address 10.10.10.14 session monitor-enabled state down } } monitor tcp }
Regarding CMP logic, TMM load-balancing independently with other TMM.
And this device is BIGIP 5250v have 8 core.
I got answer with case-owner, 8 core * 5 server = 40 / under 40 CPS, shows not LB evenly.
Current, I`m changing cmd-enable yes → no.
after work, LB is well-doned. but I don`t like CMP disable.
is there any possible way to LB very evenly not disable CMP?
etc) i-rule or ~~~
I`m very helpful anyone help this thing.
with regards,
I would recommend not setting CMP to disable. This can have very bad capacity implications on your device.
The easiest way to fairly/evenly distribute sessions among your pool members is to change the lb method to round-robin. It will distribute a connection to each member before circling back to the start. However, round-robin does not take into account how long each connection lives, which is why we generally recommend least connections for most applications.
Hi
for additional information.
CPS is very low, but each of connection highly burden Server and long live connection.
for this reason, I set least-connection and cmp disable.
but is there possible way to not disable cmp, it would be very helpful.
with regards,
