Hello Folks,
Could you please help me correcting my following iRule?
================================================================ when CLIENT_ACCEPTED { if { [IP::addr [IP::remote_addr] equals 172.22.64.0/24] } { snat 172.22.64.68 log local0. “SNATTed of SiteB” pool Test_pool }
elseif { [IP::addr [IP::remote_addr] equals 2.2.2.0/24] }
snatpool NAME_OF_SNAT_POOL
pool Pool_Name
log local0. "SNATTed of SiteA"
else { pool Normal }
I am getting following errors while adding it to my F5.
“01070151:3: Rule [/Common/Test] error: line 11: [undefined procedure: elseif] [elseif { [IP::addr [IP::remote_addr] equals 2.2.2.0/24] }] line 15: [undefined procedure: snatpool NAME_OF_SNAT_POOL pool Pool_Name log local0. “SNATTed of SiteA” ] [{ snatpool NAME_OF_SNAT_POOL pool Pool_Name log local0. “SNATTed of SiteA” }] line 21: [undefined procedure: else] [else { pool Normal }]”
I am newbie to programming, hence I couldn’t figure out the syntax error.
Seek for your help.
Thanks, Darshan
snat 172.22.64.68
log local0. "SNATTed of SiteB"
pool Test_pool
} elseif { [IP::addr [IP::remote_addr] equals 2.2.2.0/24] } {
pool Pool_Name
pool Normal
There was a closing curly bracket missing at the end (related to the event).
Make sure to have all resources defined (pools, SNATPools) before referencing them in your iRule.
Are you dealing with a large number of client IPs to translate with different SNATs? Perhaps the ‘switch’ command will be a better choice:
Hi Stephan,
Thank you very much for your reply. Yes I need to use an SNAT Pool for “Elseif” part instead of using single SNAT IP address.
Any example to use switch in this scenario? Really appreciate your help.
Cheers! Darshan
Hi Darshan, I will look for a working example based on switch.
Another alternative is using datagroups (classes).
In the following example an external datagroup (file based) is used:
[root@ltmve:Active] config cat dg_snat_mapping_ip
host 10.100.100.20 := "10.100.100.120",
host 10.100.100.21 := "10.100.100.121",
host 10.100.100.22 := "10.100.100.122",
host 10.100.100.23 := "10.100.100.123",
host 10.100.100.24 := "10.100.100.124",
network 10.100.100.0/24 := "10.100.100.126",
[root@ltmve:Active] config bigpipe class ext_dg_snat list
class ext_dg_snat {
type ip
filename "/config/dg_snat_mapping_ip"
mode read
separator ":="
set entry [class match -value [IP::client_addr] equals ext_dg_snat]
if { $entry ne "" } {
snat $entry
else {
log local0. "No SNAT for [IP::client_addr]"
Thanks,
Stephan
Hi Darshan,
the datagroup based version is more flexible regarding subnet mask length.
Using the following ‘switch’ based approach limits you to a fixed subnet mask length.
switch [IP::addr [IP::client_addr] mask 255.255.255.0] {
10.10.1.0 { snat 10.232.232.1 }
10.10.2.0 { snat 10.232.232.2 }
10.10.3.0 { snat 10.232.232.3 }
default { snat 10.232.232.4 }
Thanks,
Stephan
Hi Stephan,
Thank you very much for your extensive help. However can you please guide me how can I embed the switch command within elseif? I know its below newbie level. Apologies to embarrass you for such a nominal query.
Thanks again, Darshan
Hi Darshan,
this will be just a combination of both commands.
Now ‘switch’ will be evaluated in the context of ‘elseif’:
if { [IP::addr [IP::remote_addr] equals 10.10.0.0/16] } {
snat 10.232.10.1
} elseif { [IP::addr [IP::remote_addr] equals 10.11.0.0/16] } {
10.11.1.0 { snat 10.232.11.1 }
10.11.2.0 { snat 10.232.11.2 }
10.11.3.0 { snat 10.232.11.3 }
default { snat 10.232.11.8 }
snat 10.232.8.8
Thanks, Stephan
Thanks Stephan! Thank you very much!
Hey Stephan,
One more thing, the actual requirement is to route the SNATTed traffic to specific pool as well. So I believe I just have to add "pool " command within IF and ELSEIF statements, right?
Please confirm if its not correct.
Cheers! Darshan
Hi Darshan, you are right, it´s just adding the pool selection as an additional command i.e. as follows:
10.11.1.0 {
snat 10.232.11.1
pool pool_1
10.11.2.0 {
snat 10.232.11.2
pool pool_2
Thanks, Stephan
Hi Stephan,
In case if I am using VS IP address to SNAT my traffic from one site to another site, will it be working?
For eg. I am an ISP, I have a customer which has 2 sites hosted and I am managing his network between both the sites, along with load balancing.
So I have F5 to load balance the traffic between both the sites. The requirement is to SNAT the traffic originated from SiteA with 1.1.1.1 IP address and SNAT the traffic originated from siteB with 2.2.2.2 IP address.
And I have 2 virtual server hosted with the same IP addresses 1.1.1.1 and 2.2.2.2, do you think that above iRUle would be helpful to achieve this requirement?
Sorry to stretch you for a long.
Regards, Darshan
Hi Darshan,
if the traffic is getting a site specific SNAT, then this information will be kept in the BIG-IP´s connection table.
So in case there is a response coming back from a server, it will point to one of the SNAT addresses. Due to the existing connection table entry it will matched to the related peer and the response will be forwarded with the tuple information the client is expecting.
That´s why there is no need to configure additional virtual servers to handle responses.
I hope I got your question right. Will be on the move now …
Best regards, Stephan
Hi Stephan,
Thanks for your response. I might couldn’t describe the question well.
Let me rephrase it, Is it possible to use an existing Virutal server IP addresses as an SNAT address to manage the traffic coming from a specific network to F5?
Thanks again Stephan!
Hi Darshan, yes. The same IP can be used for both SNAT and to act as a Virtual server. Best regards, Stephan
Thanks a ton Stephan! You are a million dollar guy!!
