Unclear about persistence via irule
Hi, below the following irule. 1 website is split across 2 webservers. this is because everything under the uri /zorg or /zorgverzekering runs on seperate servers.
Also, from this seperate part of the website, it calls on scripts which have the same url as a part of the other website.
e.g.: http://www.app.nl/resources/script.js
exists for the 2 applications, but differ in content. In order to tackle this problem, i check for the http-referer.
How do i manage persistence across the 2 pools?
The F5 documentation is not very clear about this. I also found references i should be able to use a persistence profile, but this doesn not work from an irule.
I think it should be like this:
persist cookie insert “Desired_cookiename” “0d 00:45:00”
pool Application_pool_name
It inserts a cookie, but it looks like it does this for every request.
What is the best way to approach this?
The irule:
switch -regexp [string tolower [HTTP::uri]] {
“^.*zorgverzekering/(.*)” -
“^zorg/(.*)” -
“^.*zorg/(.*)” -
“^zorgverzekering/(.*)” {
persist cookie insert “Cookie_Zorg” “0d 00:45:00”
pool App_pool_zorg }
“^.*app_themes/(.*)” -
“^.*resources/(.*)” -
“^.*handlers/(.*)” -
“^.*scriptresource\.axd(.*)” -
“^.*webresource\.axd(.*)” { if {[HTTP::header value Referer] contains “/zorgverzekering/” } {
pool App_pool_zorg
else {
persist cookie insert “Cookie_Schade” “0d 00:45:00”
pool App_pool_schade
“^(.+)” { if {[HTTP::header value Referer] matches_regex “^.*zorgverzekering\.css(.*)” } {
pool App_pool_zorg
Default {
pool Ditzo_pool_schade
The KB’s will help you ,
You can also look at a similar question I asked in this community
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/2156795/showtab/groupforums/Default.aspx2232208
good luck
It would be significantly more efficient to replace the regexes with string patterns in the switch statement. You can check the string match man page for examples of the supported wildcards:
http://www.tcl.tk/man/tcl8.4/TclCmd/string.htmM35
Aaron
