im searching for a way to unchunk a http request body before sending it to the webserver which is unable to handle chunked reuqests. As both clients and servers are Appliances there is no way to configure either one for this situation and i want to avoid setting up an extra apache as reverse proxy.
Does anyone know a way to to this with iRules? Afaik our BigIP 6400 supports unchunking (at least in the GUI) only for the HTTP Response.
Thanks for your reply. I already saw that post but i’m not sure if that will work.
As i understand it this will change the request header to HTTP/1.0 so the server will send an HTTP/1.0 response. But what if this first request is an HTTP/1.1 POST with a chunked body? Just changing the protocol header won’t fix anything, will it?
