Dear Forum members. I have downloaded and setup the load balancer ova virtual machine trial. I am able to ssh the VM but not able to login via web console. When I used the credentials I face login failed. I also tried to factory default but that action is also given me unexpected responce.
System defined password should accept but not sure why not taking by F5. Can you try if GUI has disabled?
show running-config global-settings
OR
list global-settings
Can you reactive license and try
these command will run under tmsh. Add `tmsh` initial and try.
Example: tmsh show running-config global-settings
tmsh list global-settings
[root@localhost:NO LICENSE:Standalone] / # tmsh
root@(localhost)(cfg-sync Standalone)(NO LICENSE)(/Common)(tmos)#
root@(localhost)(cfg-sync Standalone)(NO LICENSE)(/Common)(tmos)# show running-config global-settings
Syntax Error: “global-settings” unexpected argument
root@(localhost)(cfg-sync Standalone)(NO LICENSE)(/Common)(tmos)# list global-settings
for reset config:
tmsh
load sys config default
for chage to admin password:
passwd admin
Just try the above method.
Get inside the shell & run the below
# passwd admin
I see you are already a root user, so you can change the password of admin.
Thanks, problem resolved.
