Unable to load config after reboot
Hello all, I’d like to consult situation on our devices.
We have two BIGIP 5250 in ‘vcmp mode’. vcmp hosts are in HA-pair, also all vcmp guests (4 guests). We upgraded all guest to 14.1.4 (from 13.0.0 directly to 14.1.4 without problems). The issue occurs for hosts. See below.
step1: 13.0.0->14.1.4. unbale to load configuartion. rollback to 13.0.0. success.
step2: 13.0.0->13.1.3.5. unbale to load configuartion. rollback to 13.0.0. NO success.
one of two HA-pair host is not loaded configuration correctly. it seems, that is not able to decrypt configuration. see the “show sys load configuration verify”:
01071769:3: Decryption of the field (secret) for object (/Common/system_auth_name1) failed.<br>Unexpected Error: Validating configuration process failed.
Wwhen I remove ‘/Common/system_auth_name1’ (there is radius secret), another part is not able to decrypt:
01071769:3: Decryption of the field (secret) for object (/Common/f5_api_com.key) failed.<br>Unexpected Error: Validating configuration process failed.
in log I can see also this:
<span>Master Key decrypt failure - decrypt failure - final</span>
‘f5mku -K’ is different for vcmp host01 (this is not able to load config) and host02 (this is running correctly). both vcmp hosts are running in HA pair (each has 4 vcmp guests in HA).
My question is, how to solve this issue without lost guests configuration on host01. Any ideas?
solution: “8-times” reboot between 13.0.0 and 13.1.3.5, and next to 14.1.4.5 (one reboot) and everything is working as expected. So “simple solution”.
