we’re using an F5 BIG-IP to load balance our windows IIS servers. We host our sites at some hosting company. Everything seems to be working fine.
When i check the LOG FILE, every ip address of the client (requesting data from the IIS server) is an IP address from (i’m guessing) within the hosting company : 64.151.105.* I know this is not the real client IP because i created a support ticket a while back and they somehow created an extra custom x-header (HTTP_RLNCLIENTIPADDR) with the real ip of the request (which i’ve confirmed is correct with various IP’s on public machines, when i dump the request information to the web page).
So … without knowing the exact version the BIG-IP hardware machine we are using is …
** Is it possible to replace the client-ip value with the user’s real one? If so, is there a help doc that can explain this please?
this way, our IIS logs will report the REAL client IP for accurate analysis.
If you can’t change the default gateway on the IIS servers to the self IP of the BIG-IP, you can configure the BIG-IP to insert the original client IP address in a custom HTTP header named X-Forwarded-For. Joe Pruitt wrote an ISAPI DLL you can install on your IIS servers to log the custom header in the IIS logs. Here are some related posts:
SOL4816: Using the X-Forwarded-For HTTP header to preserve the original client IP address for traffic being translated by a SNAT
Based on a read through of other users and Joe’s comments (Click here), it looks like the DLL will replace the value of the C-IP field in the IIS logs with the parsed value of the X-Forwarded-For header. I believe he parses out internal IP addresses and writes the remaining IPs in a comma plus (1.1.1.1, +2.2.2.2) separated list. So if the BIG-IP is configured to insert the X-Forwarded-For header and you enable this DLL on your web server(s), you should see in the C-IP field, what the BIG-IP got as the source IP of the TCP packet it received.
A self IP address is an address the BIG-IP uses to source requests as well as receive them as a gateway. Take a look at the Network & System Mgmt Guide for details (Click here).
The reason that you are seeing the BIG-IP address in the IIS logs is that you either have SNAT enabled on the virtual server or you have a default SNAT defined which matches the requests to the IIS servers. Typically the reason you would have a SNAT enabled is because the web servers do not have their default gateway set to the BIG-IP. Enabling SNAT in this scenario forces the web servers to respond back to the BIG-IP and ensures symmetric routing. I was suggesting that if you were able to set the default gateway of the web servers to the BIG-IP’s floating self IP address (or static self IP if you have a standalone unit), you could avoid the need to translate the source address of requests to the web servers.
