As I am trying to connect to the F5 BigIP (version 11.5.1) LTM device through configuration utility but url gives the following error:
Error : The page can’t be displayed.
But I am able to connect to the device using CLI.
Can anyone please help to resolve this issue
nathe
2
Are you connecting using HTTPS? i.e. https://1.1.1.1
I take it your connecting to the CLI using the management address? Do you get the correct IP when you run “tmsh list sys management-ip”?
It looks like F5 tomcat is not responding.. Restart tomcat.
bigstart restart httpd
Thanks for your response. Is it recommended to restart by using serial console connection?
