UIE Persistance Records
Im using a universial persistance profile with an irule attached.
However when I look at the persistance records I see that the client addr is not populated.
Any ideas
root@f5ltm(Active)(tmos) show ltm persistence persist-records all-properties
Sys::Persistent Connections
universal - 172.16.100.10:80 - 192.168.1.31:80
TMM 0
Mode universal
Key e2b454e150fb4d600244180790d86eb8
Age (sec.) 9
Virtual Name VS-172.16.100.10-80
Virtual Addr 172.16.100.10:80
Node Addr 192.168.1.31:80
Pool Name POOL-172.16.100.254
Client Addr ::
well as you’re not persisting on the client address, it’s just not applicable here.
True but I have another F5 with this same setup showing this value. Even though cookie persist is being used within UIE. Any ideas ?? I thought it may be down to SNAT but on testing this doesnt appear to be the case.
Thanks,
Does anyone have any idea about this ?
is client ip changed after persistence record is created? i suggest you open a support case if you want to know whether it is bug or expected behavior.
anyway, you know since persistence is not based on client ip, this won’t cause an issue.
