Can you explain what kind of behavior are you looking to do with the replacing the IP address in a payload. This might help us further understand how we can help you.
Yes of course, So, we have a data group called NATNET that includes networks: 10.12.0.0/24 10.12.1.0/24 10.12.2.0/24 10.12.44.0/24 10.12.60.0/24 Example Scenario: There is an incoming packet to our forwarding virtual server with Source IP : X.X.X.X and Destination IP : 10.20.30.12 When the packet have the destination ip that matches in the networks contained in the data group NATNET ( i can check it by using an IF condition with a scan fuction and compare it) But now inside the IF condition (So, the condition is true ) i want to Translate the destination ip like a snat irule like this: scan [IP::local_addr] “%d.%d.%d.%d” a b c d now i want to translate the Destination IP in --> 192.12.$c.$d i Hope i was clear enough to understand Thanks in advance for all your support
Thank you for your answer, i’ve tried the node command but it didn’t give me any output ( not functioning) I’ve checked my Forwaring virtual server and it didn’t have the address translate option but if i create a new virtual server i can see the option so, under the forwarding virtual server I’m not be able to use the translation commands? Thanks for support
can you change to performance layer 4 or standard virtual server? you do not need to assign pool. without pool, packet will be forwarded based on routing.
Yes i can change it, but the command node and the command translate don’t provide me the Destination IP Address translation that i want to implement So, there are other solutions to create a Destination IP translation? Thank You
