Two Virtual IP
Hi
I have one pool and two virtual IP. can these Two Virtual IP can use Same Pool.
With Regards
Ankush Narang
Ankush
Yes they can.
Rgds
N
Yes this is possible but what is something that you want to achieve?
Yes, and you avoid some issues.. ie loosing track of the same host being using in multiple pools… Some load balancing metrics within a pool can be set to “node” or “member”… “Node” will take into account the global usage, and “member” will only take into account stats within that pool..
