two remote-roles
Hello Team
I’ve searched forum and so far haven’t found any information that it is possible to assign two remote roles (for example: certificate manager and user manager on specific partition) to specific user. Is it possible in 14.1.x version ?Article https://support.f5.com/csp/article/K14324  shows only configurtion regarding one remote-role using F5-LTM-User-Info-1.
BR
TC
Hi  @T5C  ,
  I implemented a remote role before with Cisco ISE , and it works well till now.
I think it will work well with you if you create 2 remote roles.
If you want to share with you needed actions from F5 and ISE Sides I will do it.
> and  I am on release version 14.1.x.x as well.
