Two iRules that seem to conflict
Env: LTM 11.5.2 (hardware, not VM)
We have two iRules that work correctly independently, but when we apply them both to a virtual server, cause an error. The error is:
TCL error: /Common/esb-qa-secure-aws.psegliny.com-443_adjust-wsdl-endpoint - Operation not supported (line 1) invoked from within “HTTP::header remove “Accept-Encoding””
That iRule code that errs out is as follows (note that I put in the priority as an attempt to de-conflict the two iRules, but it seemed to have no effect) - it’s a pretty standard stream adjustment to rewrite some content on the way out:
     Disable the stream filter for all requests
    STREAM::disable
     LTM does not decompress response content, so if the server has compression enabled
     and it cannot be disabled on the server, we can prevent the server from sending
     a compressed response by removing the compression offerings from the client
    HTTP::header remove "Accept-Encoding"
when HTTP_RESPONSE {
     Check if response type is text
    if { [HTTP::header value Content-Type] contains "text" } {
        STREAM::disable
        log local0. "Adjusting values"
         Replace http:// with https://
        STREAM::expression {@:443@@ @pl-ts-esb-esb01.dev.psegliny@esb-qa-secure-aws.psegliny.com@ @pl-ts-esb-esb02.dev.psegliny@esb-qa-secure-aws.psegliny.com@ @pl-ts-esb-esb03.dev.psegliny@esb-qa-secure-aws.psegliny.com@ @pl-ts-esb-esb04.dev.psegliny@esb-qa-secure-aws.psegliny.com@}
         Enable the stream filter for this response only
        STREAM::enable
It operates fine, except when I add the following iRule (which also works fine, as long as the previous iRule is not applied:
    if { [HTTP::username] eq "" or [HTTP::password] eq "" } {
        HTTP::respond 401 WWW-Authenticate "Basic realm=\"AWS Alexa Credentials Required\""
        return
    binary scan [md5 [HTTP::password]] H* password
    log local0. "Pw [HTTP::password] MD5 is $password"
    if { [class lookup "[HTTP::username]" AWS-Alexa_QA_Account] equals $password } {
        log local0. "User [HTTP::username] has been authorized to access virtual server [virtual name]"
        log local0. "User [HTTP::username] has been denied access to virtual server [virtual name] using password [$password]"
I played with priority, trying to get the HTTP_REQUEST section of the 2nd iRule to apply before the 1st one, to no effect. I also moved the STREAM::disable and header removal into the 2nd iRule, to no effect.
Any thoughts? What approach will allow both of these iRules to operate at the same time?
thx!
the error you see is most likely caused because a previous iRule has already responded the ongoing HTTP request.
After the HTTP request is responded an attempt to modify the HTTP headers will create that kind of TCL exemption.
did you try to combine both irule?
        return
        return
    STREAM::disable
        STREAM::disable
        STREAM::enable
Last point, you ca notice that i add a return in irule above as specify below:
else {
        return
