I was wondering if it is possible to configure twofactor authentication on Firepass 7.0 as follow:
1. Verify username and token on RSA Server (token only configuration)
2. Verify username and password on MS Activ Directory
Thanks for any feedback
Koni
Hi Koni,
It should just be as simple as creating a new master group using RSA SecurID as the authentication choice and then when you are on the “Authentication” tab of the master group you will select “Verify domain password against Active Directory server”. You will need to configure both auth sources but it shouldn’t be difficult. You can also use RADIUS to authenticate SecurID and you don’t have to worry about using the SecurID agent… This is only if your SecurID environement is confgured to allow RADIUS auth.
Please let me know if you have any additional questions.
Thanks,
Seth Cooper
Hi Seth Cooper
Thanks, this should help me. I will try it.
