Hello,
I have followed “Deploying the BIG-IP System v11 with Microsoft Exchange 2010 and 2013 Client Access Servers Deployment Guide” and deployed Exchange 2013 CAS load balance using F5 LTM and APM (single VS). OWA, ActiveSync (EAS), Outlook Anywhere (OA) and ECP works as expected. I am trying to add RSA authentication for OWA and ECP which breaks EAS and OA since these two are under same VS, expecting a RSA credentials. I have modified the default access policy which iApp created to include RSA passcode option. I have created the following iRule. Instead of disable I need to forward the request to AD access policy. Any help is appreciated.
switch -glob [string tolower [HTTP::path]] { “/owa" - "/ecp” { ACCESS::enable } default { ACCESS::disable } } }
The access policy is, Start → Login Page (UID, RSAPasscode, AD PWD) → RSA auth → Variable Assign → AD Auth → SSO Credential Mapping → Allow.
Thanks, Surya
