When I connect to one of our F5 boxes and I run the command “b list”, it displays the output in paged format. So then I have to press the space bar to scroll through each page. Is there anyway to turn this off? The reason why I’m asking is that I have a script which runs to backup our F5 config and its waiting for a prompt but never sees it because of the paging feature.
Thanks for the info Aaron. I’m new to BigIP so I wasn’t aware of the UCS file.
I use putty to SSH into the BigIP so I’m not sure if that makes a difference but yes, running the “b list” command shows pages output and a prompt doesn’t appear until I page through the output
Not automatically. You could script the creation of the UCS on the BIG-IP using cron. The BIG-IP has the openssh package installed, so you can use SCP or SFTP in a script on the BIG-IP. Or you could run the script on the remote host.
I posted an example script in a past thread (Click here). If you end up using it, could you post an updated version to the thread and/or the Codeshare (Click here)? You may want to add logic which checks to see if the configuration has changed before either creating the UCS or copying the UCS to a remote host. You could also clear out old UCS files if they’ve already been copied to the remote host.
setting the terminal type on the client could perhaps cure this problem without having to issue a command on the host. i’m trying some variations such as ‘vanilla’ but also setting the page width and height to large numbers. getting much better results!
