Trying to implement Exchange 2010
When testing Outlook Anywhere as well as Active Sync (using using www dot testexchangeconnectivity dot com/) site I receive the following error: “Initial Anonymous HTTP(s) request did not fail but Anonymous is not a supported Authentication Method for this scenario Anonymous Authentication Enabled for Virtual Directory - Connectivity Analyzer | Microsoft Learn”
I found on Technet and Experts Exchange the identical error message and both cases said it was resolved by changing iRules but provided no further details.
We are trying to implement Exchange 2010 using the F5 deployment guide section “Configuring the BIG-IP LTM to support Outlook Web App, Outlook Anywhere, and Active Sync using a single virtual server”. OWA works OK (except when you log in and click “options” it goes to a 404 error). We are running LTM 10.1.0. Tried using the template first and that did not work well at all so moved on to using deployment guide instead and made better progress. When testing Outlook Anywhere as well as Active Sync (using using www dot testexchangeconnectivity dot com/) site I receive the following error: “Initial Anonymous HTTP(s) request did not fail but Anonymous is not a supported Authentication Method for this scenario Anonymous Authentication Enabled for Virtual Directory - Connectivity Analyzer | Microsoft Learn”
Has anyone seen this issue already? Any suggestions on what to change on the iRules from the deployment guide? They are pretty basic so frustrating I cannot get this to work. Anything else I should look for?
Mike,
I changed the default append iRule from from the deployment guide:
if { not ([HTTP::uri] starts_with “/owa”) } {
HTTP::uri /owa[HTTP::uri]
To
if { [HTTP::path] equals “/” } {
HTTP::redirect “https://[HTTP::host]/owa”
and now Outlook Anywhere appears to work correctly.
Looks like that worked!
I’m sorry I meant to post a follow up. That iRule broke OWA for us so we went back to the drawing board and now trying to setup without SSL offloading.
Brendan,
Similar problems, now we have OWA working in SSL offloading mode (had to change registry on CAS server sides to get it working), but testing ActiveSync via iPhone gives us errors about unable to verify. I will be doing more testing but I am thinking the issue is on our Exchange side. The document for the setup of the single instance is what I used (didn’t use the templates) and everything did work after we got the Exchange side fixed. It’a pretty simple ruleset - redirect to /owa add https, if RPC use source address afffinity, else use cookies. - (I think off top of my head)
This one should work (same as document) but remember it must go after the persistence rule:
Brendan (or anyone for that matter), did you find a solution to the 404 error when clicking on Options within OWA? I’m seeing the exact same thing.
In case anyone else comes across this, here’s the problem. Clicking on the “options” link in OWA sends you to a link that does not include /owa in the uri. Instead, it directs you to /ecp/?rfr=owa. The owa append iRule in the current deployment guide does not account for this. It will append /owa and break the link.
Here’s the iRule I settled on, so far so good.
if { ([HTTP::uri] equals “/”) } {
So I am still having the issue last posted on 07/02/2010 even when changing the iRule (even when removing the iRule). Has anybody else had luck with this?
I think I might have it working…finally
On our http virtual server I have 1 iRule to rewrite incoming url and redirect the https server, we are an exchange hosting company so I need to this.
if { [HTTP::host] contains “email” ||
[HTTP::host] contains “outlook” ||
[HTTP::host] contains “webmail” ||
[HTTP::host] contains “mail” }
HTTP::redirect “https:/mycas.mydomain.com/owa”
else {
HTTP::redirect https://[HTTP::host][HTTP::uri] <-non /owa requests (http://mycas.mydomain.com/ecp)
Then on the https server I have the append irule noted above and nothing else
Lastly, and I think the missing part of puzzle. Edit the http profile used for you virtual servers and change this option “Redirect Rewrite” to All (should be set to MATCH).
We found that when “Redirect Rewrite” set to “match” the requests between the client and f5 would bounce from http to https to http and so on. And cause long load times
I’m not sure if you figured this out or not, but when you click options in OWA it sends you to the ECP virtual directory.
I’m still working my way through all of this stuff but basically this is where the internal/external URL’s come into play.
We’re planning on sending all clients through the LTM’s so everything will be considered external. You have to go through and set all of the external URL’s within Exchange 2010, so for example:
owa
internal: https://server1.mydomain.com/owa
external: https://owa.mydomain.com (LTM virtual server)
ecp
external: https://ecp.mydomain.com (LTM virtual server)
you get the idea I hope.
We initially had everything setup for SSL offloading and decided that we’d be more secure going without so we tried to disable SSL offloading and ran into all sorts of problems. I’m back to doing SSL offloading and I think I’m coming down the home stretch. I’ve got activesync, owa, outlookanywhere and autodiscover working.
If I can help anyone out let me know.
I’m mainly interested in finding some better health monitors.
Also, the deployment manual is riddled with problems. The default health monitor is garbage, It looks like it was written for IIS 6.0 and there is an Irule or two in there that doesn’t work.
Hi Ken,
Thanks for the reply here and the other thread. I think the team that writes and tests the deployment guides does a great job for a majority of scenarios. But they’re not able to test every version and deployment scenario.
I would encourage you to open a case with F5 Support to give feedback on your experience with the guides--particularly if you’re stuck on something that still isn’t working. Support should be able to help troubleshoot any outstanding problems and pass your feedback onto the docs group.
Aaron
Aaron,
I’ve already contacted a support on two problems I found in the deployment guide…At least one of the issues was not a matter of my environment, there was an error in the syntax of an Irule that anyone could have taken the rule published and put it into an LTM and found that it wouldnt’ work.
