Trying to get a SNAT irule to work
Hello all , i am hoping of you very helpful people will be able help me get this working. I am not a programmer , and only just starting to learn about TCL and Irules.
I have a irule i want to use to snat a server (same a vip bounce back but i need to match on port as well)
here is my irule it excepts the syntax but does not work.
when CLIENT_ACCEPTED {
if {[matchclass [IP::client_addr] equals $::UAT_Symba_SNAT1] and ([matchclass [TCP::local_port] equals $::UAT_Symba_Port])}{
snat x.x.x.175
} elseif {[matchclass [IP::client_addr] equals $::UAT_Symba_SNAT2] and ([matchclass [TCP::local_port] equals $::UAT_Symba_Port])}{
snat x.x.x.176
don’t do any source address translation
forward
I have modified this rule which works fines as two irules i am looking for a way of combining the two irules below , in to one.
check if client_addr = any in the class
if { [matchclass [IP::client_addr] equals $::XAT_Symba_SNAT1]} {
check if the class contains the server_port requested
if { [matchclass [TCP::local_port] equals $::XAT_Symba_Port]} {
snat using this snat pool
snat X.X.X.175
forward
if { [matchclass [IP::client_addr] equals $::XAT_Symba_SNAT2]} {
snat X.X.X.176
forward
Thanks for any help or advice
What about
     if {([matchclass [IP::client_addr] equals $::UAT_Symba_SNAT1]) && ([matchclass [TCP::local_port] equals $::UAT_Symba_Port])}{
     snat x.x.x.175
    } elseif {([matchclass [IP::client_addr] equals $::UAT_Symba_SNAT2]) && ([matchclass [TCP::local_port] equals $::UAT_Symba_Port])}{
     snat x.x.x.176
     don't do any source address translation
     forward
I got this working befire the replied with this
if client_addr equals and server ports equals
if {[IP::addr [IP::client_addr] equals a.a.a.203] and [TCP::local_port] equals 25010}{
snat using this snat address as a source address
snat b.b.b.b
if {[IP::addr [IP::client_addr] equals c.c.c.204] and [TCP::local_port] equals 25010}{
snat d.d.d.d
don’t do any source address translation and forward
forward
Thnaks for your help. What a great forum, better than the response from F5 , " limited support for irules , but he did agree to look at the rule for me .
Thanks again Cmbhatt
