Trying to configure Syslog over SSL
Im trying to create an SSH key per the Solution Article at the following link:
I’m currently running 11.6, but couldn’t find the manual on how to configure for syslog over SSL/TLS. When I run the command in the article (ssh -b 2048 -f syslog_tunnel_ID -t rsa -N “” -P “”) I get the following error:
Pseudo-terminal will not be allocated because stdin is not a terminal
ssh: syslog_tunnel_ID: Temporary failure in name resolution
To avoid this error I tried the command: ssh -b 2048 -f syslog_tunnel_ID -t rsa -N “” -P “”
But still got the secondary error. ssh: syslog_tunnel_ID: Temporary failure in name resolution
I’m sure I’m missing something obvious, but can’t see it. Why am i getting what seems to be a DNS error. Aren’t I just creating a file and a key?
That page is wrong. This is the correct command:
ssh-keygen -b 2048 -f syslog_tunnel_ID -t rsa -N "" -P ""
