Trying Active-Active-Standby in LAB, 2 devices show as offline.
Hey Gents,
This was the plan:
BIGIP1-A TG1
BIGIP2-A TG2
BIGIP3-S For both TG1 and TG2
But right now all TGs are only ACTIVE on BIGIP3 and shows as “Initializing / Not Synced”.
On BIGIP3 I did tmsh list cm device unicast address
root@(bigip3)(cfg-sync In Sync)(Active)(/Common)(tmos) list cm  device unicast-address
cm device bigip1.akm.com {
    unicast-address {
            effective-ip 192.168.20.50
            effective-port cap
            ip 192.168.20.50
            port cap
            effective-ip 10.128.1.243
            effective-port cap
            ip 10.128.1.243
            port cap
cm device bigip2.akm.com {
    unicast-address {
            effective-ip 192.168.20.51
            effective-port cap
            ip 192.168.20.51
            port cap
            effective-ip 10.128.1.244
            effective-port cap
            ip 10.128.1.244
            port cap
cm device bigip3.akm.com {
    unicast-address none
Since its’s all a lab, here are the QKVIEWs on gdrive for all 3 devices.
Thanks a ton for the help!
What are the unicast network failover ip addresses on bigip3.akm.com??
Cheers,
Kees
First make sure each device in the Device Group has the following configured correctly,
  • Configsync Ip
  • Mirroring IP
  • Failover Unitcast IP/Multicast IP
Once corrected ensure each device has the other 2 devices listed correctly and as connected under
Device Management  ››  Device Trust : Peer List
You may need to delete and redo the Trusts to ensure all three trust each other and see each other as connected.
If you run
show cm device
you should see something like this:
CentMgmt::Device: f5vm01.test.lab
Hostname                        f5vm01.test.lab
Mgmt Ip                         10.0.0.11
Configsync Ip                   192.168.0.11
Mirroring IP                    192.168.0.11
Mirroring Secondary IP          ::
Failover Multicast IP           ::
Failover Unicast IP(s)          192.168.0.11
Device HA State                 active
Device HA Load Capacity         0
Device Current Load Factor      1
Device Next Active Load Factor  0
CentMgmt::Device: f5vm02.test.lab
Hostname                        f5vm02.test.lab
Mgmt Ip                         10.0.0.12
Configsync Ip                   192.168.0.12
Mirroring IP                    192.168.0.12
Failover Unicast IP(s)          192.168.0.12
Device HA State                 standby
Device Current Load Factor      0
Device Next Active Load Factor  1
CentMgmt::Device: f5vm03.test.lab
Hostname                        f5vm03.test.lab
Mgmt Ip                         10.0.0.13
Configsync Ip                   192.168.0.13
Mirroring IP                    192.168.0.13
Failover Unicast IP(s)          192.168.0.13
Then setup your traffic groups, one at a time,
show cm traffic-group traffic-group-1 traffic-group-2
should look like this:
CM::Traffic-Group
Name             Device                 Status   Next
                                                 Active
traffic-group-1  f5vm01.test.lab        active   false
traffic-group-1  f5vm02.test.lab        standby  false
traffic-group-1  f5vm03.test.lab        standby  true
traffic-group-2  f5vm01.test.lab        standby  false
traffic-group-2  f5vm02.test.lab        active   false
traffic-group-2  f5vm03.test.lab        standby  true
