Is there any way to troubleshoot if problem is the connection is from:
client to load balancer OR
load balancer to webserver ?
There are logs to see but it is very generic (SSL handshake fail)
Is there any way I can learn more to troubleshoot?
@Businessuser You can do a tcpdump for the client who’s having an issue, save it, open it in wireshark and decrypt it using the SSL key. The following document should assist you.
You can disable the “Generic Alert” setting in the ssl profile to see more detailed error messages.
Hi
Use this command to collect the packet capture. you will get the client to LB and LB to webserver connection in the wireshark. Please analysis and you will able to find where it got failed
tcpdump -nni 0.0:nnnp -s 0 host “vip ip” -w /var/log/sslissue.pcap
BR
Aswin
