Troubleshoot iRule for HTTP header rewrite
I am not a iRule expert :slightly_smiling_face:
What the client wants is that, if the client browse https://cv89ppen.hrms.com, it will be forwarded to cv99pp.hrms.com/psp/CV89PP/?&cmd=login&languageCd=ENG.
or if the client browse https://cv89ppfr.hrms.com, it will be forwarded to Loading....
or if the client browse cv89pp.hrms.com, it will simply append “/CV89PP/signon.html”.
The virtual server does the SSL offloading.
For any reason, only the append part worked. Nothing happened when client browse https://cv89ppen.hrms.com/ and https://cv89ppfr.hrms.com, and it even won’t leave the logging information.
Can anybody take a look? Below is my iRule.
Thanks.
log local0. “Client [IP::client_addr] is accessing [HTTP::host][HTTP::uri]”
if {[HTTP::uri] equals “/”} {
switch -glob {string tolower [HTTP::host]} {
   "cv89ppen.hrms.com" {
                       HTTP::header replace Host "cv99pp.hrms.com"
                       HTTP::uri "/psp/CV89PP/?&cmd=login&languageCd=ENG"
                       log local0. "Client [IP::client_addr] is redirected to [HTTP::host][HTTP::uri]"
   "cv89ppfr.hrms.com" {
                       HTTP::uri "/psp/CV89PP/?&cmd=login&languageCd=CFR"
        "cv89pp.hrms.com" {
                       HTTP::uri "/CV89PP/signon.html"
Is the iRule assigned to both VIPs (port 80 and 443)?
No it only applied to VIP on HTTPS.
The VIP on HTTP simply redirected to HTTPS.
can you try to change from {string tolower [HTTP::host]} to [string tolower [HTTP::host]]?
